1994 Lexus ES 300
1994 LEXUS ES 300
LEXUSCLASS2
Engine Mechanical problem
1994 Lexus ES 300 6 cyl Two Wheel Drive Automatic
hello this louis from Tx... have a 1994 lexus es300 high mileage but runs good considering had the engine rebuilt but dont think they did the rings... can bandage it help out long as i keep use it and check the oil can this do till i get it overhual again?
Aug 18, 2010 at 4:58 PM
  • 31,937 POSTS
If the rings were no done in a re build, i would be asking why, this is the most important part of a re build. if it is using oil, there is not a lot you can do, i would be getting a leak down test done to see how bad they are.
Mark (mhpautos)
Aug 18, 2010 at 7:18 PM
