1993 Lexus ES 300 Leaking gas from tailpipe, engine floodin
CHIMUELO
Engine Performance problem
1993 Lexus ES 300 6 cyl Front Wheel Drive Automatic
Don't know what to do already change spark p,dist,injectors and comp please help
Feb 28, 2010 at 11:10 PM
DOXENG
I had the same problem once, check the following:
you might have a shorted injector
You might have a faulty ECM as a result of a short in the wires that come from the ECm and connect to the injectors.
Your best bet is to check all the wires first to see if you have a short in the wires , then check the injectors and last look for an ECU - ECM
I hope this helps.
Doxeng
Mar 6, 2010 at 11:23 AM
