HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Lexus
ES 300
Engine
Intake Manifold
Gasket
Replace/Remove
1993 Lexus ES 300 intake manifold gasket
JIMSUE
MEMBER
1993 LEXUS ES 300
6 CYL
2WD
AUTOMATIC
135,000 MILES
What is the procedure to replace the intake manifold gasket. What parts do we have to take off
Sunday, June 15th, 2008 AT 9:26 AM
BLACKOP555
MECHANIC
Disconect and mark everyuthing, maybe even take a few pictures.
next would be to remove the manifold bolts and pull off the manifold, clean off the mating surfaces and install the new gasket.
reverse for installation
https://www.2carpros.com/kpages/auto_repair_manuals.htm
for more information.
Sunday, June 15th, 2008 AT 1:22 PM
Please
login
or
register
to post a reply.
Related Intake Manifold Gasket Replace/Remove Content
How To Remove The Intake Manifold
I Am Trying To Change The Spark Plugs In The Back Of The Engine Underneath The Intake Manifold Looking For Ideas
Asked by
karlhastings
4 IMAGES
1992
LEXUS ES 300
Engine Turns Over But The Timing Belt Does Not Move?
My Car Turns Over But The Timing Belt Does Not Move. I Have Verified That The Crank Turns But The Cams Are Not And The Timing Belt Isn'...
Asked by
tonywj
1 ANSWER
14 IMAGES
1993
LEXUS ES 300
How Much Should A Replacement Engine Cost For This...
Oil Engine Light Was On For About Two Weeks. Two Mechanics Inspected It, No Other Symptoms Appeared; Car Was Running Normally. Oil Was...
Asked by
Richard Kleiner
1998
LEXUS ES 300
P1155 Air Fuel Metering Or Oxygen Sensor?
Engine Performance Problem 1999 Lexus Es 300 6 Cyl Automatic 140, 00 Miles A Friend Hooked Up My '99 Es 300 To Diagnose (check...
Asked by
LxsES300
4 IMAGES
1999
LEXUS ES 300
1995 Lexus Es 300 M A F - Massive Air Flow Sensor
I Dont Know How To Fix It I Got Two Codes On P0125, P0100 An Di U Give Me Instructions It Be Cool
Asked by
nabikhaja
1 ANSWER
1995
LEXUS ES 300
VIEW MORE
Throttle Bore & IAC Service Toyota Tacoma
Cooling System Pressure Test
Throttle Actuator Service
