1993 Lexus ES 300 engine missing
WOODY57WOOD
Engine Performance problem
1993 Lexus ES 300 6 cyl Two Wheel Drive
when trans.is in park and engine is rebbed up sounds fine soon as i put it in gear it starts to miss.
Nov 20, 2009 at 5:46 AM
  • 75,988 POSTS
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Nov 20, 2009 at 6:03 AM
