1993 Lexus ES 300 Blown Head Gasket
1993 LEXUS ES 300
WUKKAWUKWUK
Engine Mechanical problem
1993 Lexus ES 300 6 cyl Front Wheel Drive Automatic
The repair will be in excess of 2,000.00
Is there a quick fix that will get me through the next month or so?
Dec 29, 2008 at 1:33 PM
  • 31,937 POSTS
Hi there,
I wot go for any quick fix in a can, they can cause more problems, if you don't fix this correctly you run the risk of doing a lot more damage or even destroying the engine, if you cant fix it now i would not drive it, and use if you decide to use a stop leak solution, follow the instructions and get it repaired ASAP, we are not at liberty to recommend any brands.
mark (mhpautos)
Dec 29, 2008 at 1:47 PM
