1992 Lexus ES 300 transmission sluggish
69,600 MILES • 6 CYL • FWD • AUTOMATIC
1992ES300SJPR
I just got the car aligned and had the rack and pinion bushings replaced and the tie rods and the swaybar bushings replaced. The day after I got th car back from the shop the tranny went out on a hill. when the accelorator is depressed the engine revs and the car hardly moves forward. I notices that the OD/off light started to Blink which is not normal. I check the fluid level and it looked fine. Also when the tranny is shifted into REV it grabs hard.
What could the problem be?? Could it be a sensor cable that came loose or a vacume hose or do i need a new tranny???
Thank you, 1992 ES300 SJPR
Feb 12, 2008 at 8:18 AM
  • 75,988 POSTS
Get the throttle position and vehicle speed sensor checked-the computer uses it as signal indicators of throttle and governor pressure to command shift solenoids to opearte.
Feb 14, 2008 at 4:34 PM
GINO12
great answer
May 28, 2013 at 2:23 AM
