1992 Lexus ES 300 COULD I HAVE A CRACKED HEAD GASGET
163,000 MILES • 4 CYL • 2WD • AUTOMATIC
DANIELLE28
I recently purchased a 1992 lexus before I purchased a new termastata was put in because the car was over heating.. About two days after I had the car the car begain over heating again I took it to a shop and it was all out of anti freez... I was told to and to check the level of the anti freez in the moring when the engine was cold, which I did and it was fine for about 4 days and the car begain to act like it was going to stall and white smoke begain coming out of the tail pipe, the car begain running hot and when I try to refill the anti freez it seems act as if there is a leek because it all comes out under the car..and now the car will not start.. PLease could it be a cracked head gasget?
Feb 20, 2008 at 6:46 AM
  • 75,988 POSTS
If there's no actual leaking-Get it block and pressure tested to identify a blown headgasket cracked head/block.
Feb 20, 2008 at 6:52 AM
DANIELLE28
it is leaking because when you put anit freeze in it cames out
Feb 20, 2008 at 7:07 AM
  • 75,988 POSTS
Could be leaking from the radiator/hoses/water pump/freeze plug/s.
Feb 20, 2008 at 7:50 AM
