1990 Lexus ES 250 Won't start
1990 LEXUS ES 250
COCHRAN6698
Electrical problem
1990 Lexus ES 250 6 cyl Front Wheel Drive Automatic
Change battery, interior lights come on but tail lights and clock won't work and it still won't start.
Dec 25, 2009 at 3:29 AM
Is it cranking over and will not start or just won't crank at all/nothing??
Dec 25, 2009 at 8:42 AM
COCHRAN6698
It won't start. It was jumped before and started and then it wouldn't start even with a jump. Bought a new battery and it still won't start. The interior lights come on and also the headlights. No tail lights and no dashboard lights. When key is in the on position, nothing happens.
Dec 25, 2009 at 8:54 AM
Double check battery condition and connections if okay and still nothing when key at starting postion check and test the ignition switch
Dec 25, 2009 at 12:21 PM
COCHRAN6698
How do you check the ignition switch to see if it's working?
Dec 26, 2009 at 3:05 AM
Sir- if you don't have electrical background bring it in you could make things worst than it is.
Dec 26, 2009 at 12:09 PM
