1991 Lexus ES oil capacity
1991 LEXUS ES
153,000 MILES • 6 CYL • 2WD • AUTOMATIC
KLSCARRELLA
I have a 1991 lexus es 250. No owners manual, was wondering oil capacity so I could change engine oil and filter. Also, Was wondering where the thermostat is located on this car? Thank You
Oct 5, 2008 at 4:27 AM
BLUELIGHTNIN6
  • 16,542 POSTS
4.1 quarts if you are replacing filter, 3.9 quarts if you are not replacing filter. to locate thermostat just follow lower radiator hose to engine, it is located there inside the thermostat housing.
Oct 21, 2010 at 4:10 PM
