1991 Lexus ES Fan Controller
1991 LEXUS ES
SUPERLUMENY
Engine Cooling problem
1991 Lexus ES 6 cyl
91 Lexus ES-250....Problem with radiator fans...
Proper function...
Prime fan and AC fan....both fans only came on as necessary...Prime fan first...then AC fan as needed...they each would shut off when not needed....
NOW...they both run constantly...they won't shut off...
...what & where is the sensor, control module (?) that controls them....???? thanks...
fan control module
Sep 10, 2008 at 4:41 AM
DOCFIXIT
  • 18,828 POSTS
Hi Superlumeny
Assuming fans cut off when key is off they both come on as soon as you start the engine. If true accodring to the Toyota training I've had most likely cause Is a defective AC High pressure switch. Located in junction block near receiver drier.
Pull plug Ohm between switch terminal, make sure AC has not been run for a while,if you read no continuity ie. open then switch is bad.
Hope this helps
Thanks for your donation
Sep 11, 2008 at 5:05 AM
