after replacing the evaporator core left headlight, blinker, and taillight do not work?
110,100 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
KENNETH PARKER
We took the dash out to replace the evaporator core and we put everything back the way we took it out and now the left headlight and left blinker and the left rear running light do not work anymore?
Sep 18, 2023 at 2:02 PM
  • 55,682 POSTS
There is a ground G203 at the left side of the dash kick panel, I would check this first. If that is okay let's check the fuses, this guide can help:
Please go over this guide and get back to us.
Sep 20, 2023 at 11:12 AM
KENNETH PARKER
I checked the plug that goes to the lights, and I am not getting any power to the left side lights and the right side has power.
Sep 21, 2023 at 12:42 AM
  • 55,682 POSTS
Did you check the ground I have mentioned?
Sep 23, 2023 at 3:24 AM
KENNETH PARKER
Ken L, yes I have they are all tight.
Sep 23, 2023 at 8:34 AM
  • 55,682 POSTS
Okay, when you did the job did you remove the BCM? I would try checking the plugs. Also, let's try resetting the computers by following this guide:
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
If this doesn't work, we need to run the codes by doing a CAN scan. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Please go over these guides and get back to us.
Sep 24, 2023 at 3:36 AM
KENNETH PARKER
Ken L, I just put it in the shop, and they found that the fuse in the #3 spot on the fuse panel in the dash was missing but it is fixed now. thanks for the advice.
Sep 26, 2023 at 10:28 AM
  • 55,682 POSTS
Did you remove the fuse? I don't understand how the fuse can be missing?
Sep 27, 2023 at 1:28 AM
