Left turn signal and low beam bulb out
114,000 MILES • 1.0L • 4 CYL • 4WD • AUTOMATIC
TORILYN50
I have two problems. My left hand turn signal is clicking fast and my low beam left headlight is out. First of all are those two problems related in any way? Secondly, I bought a replacement bulb for the headlight and they are telling me it is the wrong one and has to be HID.
Thanks,
Victoria
Jul 29, 2019 at 3:15 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Those are two different issues. Now for the bulb, either it has halogen bulbs or xenon bulbs. The only way to be sure which you have is to remove them. I will tell you that to replace a headlamp bulb requires removal of the front bumper fascia. I am going to provide the directions for removal of the fascia so you can access the bulbs and identify them.
First, here are the directions for bulb replacement:
HALOGEN TYPE
FRONT COMBINATION LAMP
Removal and Installation
REMOVAL
CAUTION:
Disconnect the battery negative terminal or the fuse.
1. Remove front bumper fascia. Refer to See: Front Bumper > Removal and Replacement > Exploded View.
2. Remove the headlamp mounting bolts and nuts.
3. Remove the mounting stud of the headlamp outside from front fender.
4. Pull out the headlamp assembly forward the vehicle.
5. Disconnect the connector before removing the headlamp assembly.
INSTALLATION
Install in the reverse order of removal.
NOTE:
After installation, perform aiming adjustment. Refer to See: Headlamp > Adjustments > Halogen Type.
__________________________________________
FRONT COMBINATION LAMP (Xenon)
REMOVAL
CAUTION:
INSTALLATION
NOTE:
After installation, perform aiming adjustment. Refer to See: Headlamp > Adjustments > Xenon Type.
Fascia removal (basically, you need to remove the front bumper cover.)
(see pic 1 below for mounting pin locations.)
Once the bulb is removed, confirm which you have.
Let me know if you have questions.
Jul 29, 2019 at 1:31 PM
TORILYN50
Jiffy Lube told me I need an HID bulb. Do you know what that is or if that makes any sense to you? I won’t be able to do this replacement myself. Do you think I should take it to Nissan dealer or a mechanic? Thank you
Victoria
Jul 31, 2019 at 7:41 AM
  • 110,248 POSTS
Welcome back:
I totally understand. I can't believe the bumper cover needs removed to replace a bulb. So many are link that anymore. As far as if it's an HID bulb, it could be. However, there are different ones used on these vehicles.
You don't need a dealer to do this. It's a pain, but not all that hard. Any decent mechanic should be able to do it with ease.
Please let me know if you get it taken care of or if you need help. One last thing, it calls for aprox 30 minutes to replace it. So don't let people take advantage. See the pic below. I highlighted the labor as provided by Alldata.
Jul 31, 2019 at 11:27 AM
TORILYN50
I would like to buy the bulb myself to save money and bring it to mechanic to replace. Is there any way to find out what bulb to purchase without removing the bumper and looking at the old one? I doubt if a mechanic has the bulb I need at his shop...
Jul 31, 2019 at 1:08 PM
  • 110,248 POSTS
Welcome back:
If you look at pic 1, it shows the HID module. If that is on your vehicle, they are HID.
Now, I looked in another manual and found a totally different set of directions. See if this is something you can do. I will include for both HID and non HID. According to this manual, the bumper cover doesn't need removed and the bulb can be replaced from under the hood.
Make sure to disconnect the battery first.
Replacement
CAUTION:
- Disconnect the battery negative terminal or the fuse.
- After installing the bulb, install the resin cap and the bulb socket securely for watertightness.
HEADLAMP BULB (LO)
1. Remove the air duct*. Keep a service area.
*When replace a left.
2. Rotate the resin cap counterclockwise and unlock it.
pic 2
3. Rotate the bulb socket counterclockwise and unlock it.
4. Unlock the retaining spring. And remove the bulb from the headlamp housing assembly.
CAUTION:
Never break the xenon bulb ceramic tube when replacing the bulb.
HEADLAMP BULB (HI)
1. Rotate the bulb socket counterclockwise and unlock it.
2. Disconnect the connector. And remove the bulb.
FRONT TURN SIGNAL/PARKING (SIDE MARKER) LAMP BULB
2. Remove the bulb from the bulb socket.
Halogen Type
Vehicle Lighting and Horns Headlamp Service and Repair Removal and Replacement Replacement Halogen Type
HALOGEN TYPE
Replacement
CAUTION:
HEADLAMP BULB (LO)
2. Rotate the bulb counterclockwise and unlock it.
3. Disconnect the headlamp bulb connector.
4. Remove the bulb from the headlamp housing assembly.
HEADLAMP BULB (HI)
Let me know if that helps.
Jul 31, 2019 at 2:36 PM
