Left Turn Indicator Quick Speed after bulb replacement
2011 KIA SORENTO
143,000 MILES • 4 CYL • 4WD • AUTOMATIC
NARCSISUSS
  • 9 POSTS
My left turn indicator still flashes quick. The left front bulb does not turn on, even after I replaced it. I believe it's one long, then the rest quick. I did hit a deer a couple of months back and they replaced the entire light and front end. It had been working. What do I need to do to get it working?
Thanks!
Sep 7, 2019 at 11:33 PM
  • 110,244 POSTS
Welcome to 2CarPros.
First, and don't laugh, did you use the correct bulb?
If you did, then I need you to check if there is power to the socket. You can use a test light for the test.
Let me know what you find.
Sep 8, 2019 at 12:48 PM
