Left rear wheel stuck after pedal depressed. All others ok
250,000 MILES
TIM HAR
Lft rear wheel stuck. Burnt pads on left only. Replaced pads. Caliper retracts easily. Push brake LR locked. Cup pushes back easily. Thinking hose. But don't understand how caliper can be pushed back so easy. Also thought proportioning valve but....
Feb 29, 2016 at 12:19 PM
CAR-MAN145
  • 321 POSTS
push on the brake till the wheel is locked then loosen bleed screw if it releases then bad hose if not then bad caliper
Feb 29, 2016 at 6:17 PM
TIM HAR
Thanks!!!
Mar 1, 2016 at 8:20 AM
