Left rear turn signal and reverse light no power?
36,000 MILES • 6 CYL • 4WD • AUTOMATIC
KENNETH FERGUSON
Vehicle was hit and damaged and then filled with water and now no power to either on left rear
Aug 14, 2024 at 11:54 PM
  • 110,248 POSTS
Was the rear light damaged and is that what filled with water? If so, have you checked to make sure there are no bad fuses? If it filled with water, it likely caused the fuse to blow.
joe
Aug 15, 2024 at 12:36 PM
