Left rear taillight assembly not working
130,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
DCOXON
I have changed all the bulbs and still no lights work all other lights work on the car. But nothing in the left taillight assembly works.
Feb 28, 2022 at 10:39 AM
We need to check the voltage that is getting to the rear taillight assembly to see if there is anything there.
I am attaching the wiring diagram below as well that will help with this. However, you have a single wire coming in that we need to check when you have the lights turned on.
It is unlikely that this is a ground issue since it appears they are shared ground for the rear lights so let's start with checking what is there, and I am sure we will find a wiring issue or a fuse block issue.
Let me know what questions you have.
Thanks
Mar 1, 2022 at 10:26 AM
