Left passenger wheel shakes badly
215,000 MILES • V8 • AUTOMATIC
MIKE HOLLIDAY
My passenger door seat is indicating a bad shaking problem with my truck. a mechanic said he replaced all tires and it still shook. I do not believe him because he later diagnosed a out of round disc but it still shakes. i had a new set of Michelin's installed when the problem started, but they put a new set on and still the shaking occurs. i had a new set of plugs installed and i have not mentioned to anyone that maybe a wire got crossed, after having the wheels rotated after an oil change. i had to have the wheels re-balanced because it shook so bad. Feel it is definitely in the tires or suspension. ny suggestions?
Feb 7, 2017 at 2:10 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Hi Mike,
Here are a few possibilities....
Bad or missing body bushing
Out of Balance drive shaft
Bent Tire Rim
Bad Shocks
Bad or Missing Engine mount bushing
If it were a brake disc or even brake drum you'd feel the brake pedal pushing back at you when braking, kinda like a pulsing feeling.
Hope this helps
Mark
Feb 7, 2017 at 8:21 AM
