left park light not working
225,240 MILES • 6 CYL • 2WD • AUTOMATIC
1502WS
  • 6 POSTS
The left park doesn't work, turn signal works four ways work. I changed the bulb and the harness. when you turn on the lights the left one will not come on. where do i start to check for the short?
Nov 13, 2021 at 6:51 AM
  • 110,246 POSTS
The left parking lights have a dedicated fuse. Have you checked the fuse? It is located in the under-hood fuse box. I highlighted the fuse in pic 1 below.
When checking that fuse, confirm the fuse is good and also make sure there is power to and from it. Here is a link you may find helpful:
The remaining pics show the wiring schematics. I highlighted the wires for the left rear light. You can use these as a guide.
See pics below. Note: The wiring schematics had to be cut in half to make them readable for you. I did overlap them so you can follow from one to the next.
Nov 13, 2021 at 4:09 PM
1502WS
  • 6 POSTS
Thanks, you guys are the best I needed the wire schematic, I'm going out to check the wires. If I find the problem. Will let you know. Thanks
Nov 14, 2021 at 5:58 AM
  • 110,246 POSTS
You are very welcome. Let me know what you find or if there is anything I can do to help.
Nov 14, 2021 at 10:52 AM
