Left Low Beam Fuse keeps blowing?
196,500 MILES • 3.5L • V6 • 2WD • AUTOMATIC
RDAVIS1
fuse 42 keeps blowing. just blew two 15A spares testing it. they blow immediately. i can’t turn on switch and step around see if bulb comes on before it blows.
Sep 15, 2025 at 1:02 PM
  • 55,851 POSTS
The first thing I need is to verify Fuse 42 is TAIL or PANEL circuit (it should be in your fuse box lid label). Next, I would check the trailer wiring connector which are famous for shorting out. Then turn the headlight switch on running lights only to see if the fuse blows, if so I would start buy removing the bulbs to check the sockets. They can overheat and melt causing the short. Here is a guide to help.
https://www.2carpros.com/articles/no-tail-lights-exterior-running-lights-tail-lights-out
Please give me more information to help you. Upload images of anything you find that may cause the problem please.
Sep 16, 2025 at 4:34 AM
