Left front turn signal flashes fast
85,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
LORA E
I replaced the bulb for the left front turn signal. Now both left and right turn signals are flashing fast but the bulbs do not light up. I can replace the other bulb but is something else going on that I should consider first?
Nov 23, 2018 at 8:44 AM
Good evening
The flashers go fast when bulbs are out leaving an open circuit.
Replace the rear bulbs and see if the flashing is normal.
if the bulbs continue to burn out, check for water in the lens. if there is then you will have to replace the tail light assembly.
https://www.2carpros.com/articles/turn-signal-bulb-replacement
https://www.2carpros.com/articles/turn-signals-blink-rapidly
Nov 23, 2018 at 9:48 AM
LORA E
I changed all the turn signal bulbs and checked the sockets for each of them. The front turn signal bulb socket on the driver side show some melted plastic has occurred. How can I find out why this happened?
Jan 9, 2019 at 4:27 PM
The melted plastic is from heat from a bad connection.
Replace the socket with a new one and retest.
You can get a replacement socket at a parts store and it will come with the wires and all to install.
Jan 9, 2019 at 9:08 PM
