Left brake light out. Right turn signal and the left one blinks too.
Nov 13, 2017 at 7:30 AM
STEVE W.
✓Experienced Mechanic
If both turn signals work but the Left brake lamp is out check the hazard lamp module in the fuse block in the center console. The stop and turn use the same filament in that bulb but are fed through the module based on which item is active.
