LED Lights high beams conversion
73,622 MILES • TURBO • 2WD • AUTOMATIC
AUSTIN BRADLEY
I have the car listed above SE model. I have converted the low beams to LED. Now I’m looking to convert the high beams to LED. My high beams seem like a perfect fit for the stock bulbs. But the connector for the led conversion kit seems like it is going to be to big to have it fit properly. I could use some help!
Jan 2, 2020 at 12:05 PM
94 TRANSAM
  • 680 POSTS
Have you searched the internet for LED head lights? To my knowledge they make LED's in all bulb styles to just replace with no conversion. For instance if I search for a 9006 headlight bulb but type in 9006 LED I will find that exact fit headlight in LED. So search your bulb # for an LED version. You should be able to find the bulb # on the old bulb.
If you can't find one, post your bulb # here and I can get you a link to one.
Rich
Jan 2, 2020 at 1:44 PM
