What is the number for the LED headlight bulbs that will fit this truck?
188,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
MICHAEL NEEDS HELP
  • 23 POSTS
Also, I need to know if I need anything special or can I buy the bulbs and just plug them in and go. Do I need all 4 replaced low beams and high beams or can I just replace the lows beams?
Nov 9, 2023 at 11:45 PM
  • 55,721 POSTS
Here are your choices:
https://amzn.to/3MCsNZA
I see the lens as well so you can replace the entire headlight housing. Here is how the job is done:
https://youtu.be/ejoAuY7R6y8?si=dEtnT9v45ypLB6e8
Let us know if you need anything else, please.
Nov 10, 2023 at 2:23 AM
