I installed LED high-beam headlights with also run as my DRL. people keep flashing me is there a way to have them dim in the day?
Apr 12, 2019 at 9:52 AM
✓Experienced Mechanic
Welcome to 2CarPros.
There is nothing to change the brightness. To dim them would require some sort of resister to reduce power to the bulb. However, then they would be dim all the time.
Apr 12, 2019 at 2:22 PM
NICK DAHLKE
MEMBER
It is aimed to OEM spec.
Image (Click to enlarge)
Apr 12, 2019 at 9:02 PM
Welcome back:
If you think it is caused by how they are aimed, did you check it with a headlight aiming machine?
Apr 13, 2019 at 10:53 AM
THINDERKID
MEMBER
I thought mine was also too bright but then after 3 months, it became a little dimmer. I think if you have a new bulb then that is really the case.
