Lean condition and MAF performance
169,000 MILES • 4 CYL • AUTOMATIC
KATELILY
A couple of months ago I had the water pump changed because it was leaking. Not too long after I had the check engine light come on and off. The car stalled at a stop sign and when I took it to the mechanic he said it was the MAF sensor so he replaced it. Has not stalled since. The check engine light still came on and off and the same mechanic said it was an O2 sensor. A family friend checked my car and replaced a coil, all four spark plugs along with the starter because it had trouble starting on two occasions. He also cleaned the top O2 sensor. There are times when the CEL is off and when I start up the engine it will make a weird sorta like a gurgle noise for a couple seconds which will trigger the CEL to turn on. Everyday when I start up the car the engine is loud and the rpm's will rise and fall between 1.5-2 rpm. A couple minutes later when the car beings to warm up the engine simmers down and the rpm huddles around 1. The CEL still comes on and is currently reading a P0171 and PO101 code. With these combined codes, what could be the problem?
Aug 29, 2017 at 3:49 PM
WRENCHTECH
  • 20,758 POSTS
Okay, first thing is there is no way to "clean up" and 0/2 sensor. If he put any sort of chemical at all on the sensor, he has likely ruined the sensor and it will have to be replaced.
You have a lean code that we do not know if it can be believed or not due to the unknown condition of the 0/2 sensor.
I would check for any tears in the intake snorkel or lines left off that would introduce un-metered air into the system after the MAF. You can also clean the MAF wire with MAF cleaner.
Aug 30, 2017 at 3:25 AM
