Lean after cam swap
2003 CHEVROLET AVALANCHE
300,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
ERIC YODER
I just swapped out my cam and valve-train components in my heads, and ported and polished my exhaust and intake ports and base tuned. drove fine for a couple days then it didn't start. Engine light started flashing when I did finally get it started so i hurried up and in the laptop and plugged it in. P0300 Multiple/Random misfire. No leaks, had the head off didn't see anything. Shut the injectors off one by one and they all work. And no mix in fluids. Is it possible that when I ported the head I thinned out a port and it crack that way? Any other ideas? I gotta get this thing running again. please help. Thanks in advance. -Eric
Apr 17, 2019 at 6:56 PM
Good morning,
I suspect a fuel delivery issue. The 300 code is common for low fuel pressure from a bad fuel pump.
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
Can you check the pressure?
Apr 17, 2019 at 8:31 PM
