Code 25 Air/fuel ratio Lean?
140,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
TOYOTA93
Code 25 Air/fuel ratio Lean showing up, how could i fix it?
Jun 7, 2024 at 1:12 PM
  • 110,248 POSTS
A lean fuel mixture can be caused by a few different things. First and most commonly, an engine vacuum leak. If there is a leak, it allows unmetered air to get into the combustion chamber and causes a lean fuel mixture.
Next, if there is an exhaust leak before the O2 sensors, that can also cause it. The other common cause is a weak fuel pump or restricted filter.
Start by checking for a leak.
here is a link that explains how to do it:
Try that and let me know what you find.
Jun 7, 2024 at 2:06 PM
