I just replaced the head gaskets and reassembled the engine.
The issue has to do with a leaky heat pipe connection to the manifold at the thermostat housing.
I purchased and installed a new GM O-ring to no avail.
Is there a trick in getting this to properly seal?
The pipe in question is #11 in this attached chart and the O-ring is #13.
Thanks
Thanks
Sep 27, 2019 at 7:01 AM
