Leaky fuel line
200,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
TIMOTHYDUBOSE6
I have been trying to find out the name or the fix to the quick connect fuel line that comes off the fuel injector rail down to the hard line that goes to tank
Sep 24, 2021 at 12:35 PM
SQM
  • 6,383 POSTS
Would it be possible for you to upload a picture of the line you are mentioning?
It is the part where the nylon hose goes into the metal line?
https://www.2carpros.com/articles/how-to-replace-a-fuel-injector
Please let me know what you got.
Sep 24, 2021 at 1:56 PM
  • 110,251 POSTS
There are three different types of quick-connect fittings that are used to attach various fuel system components, lines, and tubes. There is a single-tab type, a two-tab type, or a plastic retainer ring type.
Take a look at the three pics I attached below and let me know which one appears to be the type used for your vehicle. Note: These fittings, in most cases, have an o-ring in them that can be easily damaged. So, be careful when removing and replacing them. Also, the o-ring should be lubricated with motor oil or even Vaseline to prevent damage.
I suspect you have the push-on type with the latch clip (pic 3) if it is on the rail, but I just want to be sure. Also, make sure you have released fuel pressure prior to disconnecting the system.
Let me know what I can do to help.
Sep 24, 2021 at 2:02 PM
