leaky fuel injectors
100,000 MILES • 2.6L • 6 CYL • TURBO • 4WD • MANUAL
KYLE.G
when I turn the car on and the fuel starts pumping, there is an abundant amount of fuel leaking from the top of the fuel injectors. i was wondering what would cause this issue? from the research I have done it is pointing more towards the o-ring being at fault.
Dec 16, 2019 at 11:45 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Yes, you are absolutely correct. Make sure they are not cracked,pinched, or deformed into the orifice. Hope this helps and thanks for using 2CarPros.
Dec 16, 2019 at 11:55 PM
