Leaking anti-freeze and oil
20,000 MILES • 5.8L • V8 • 2WD • AUTOMATIC
BILL BUNNIS
anti-freeze and oil leaking on top of intake near intake bolts.
Mar 19, 2018 at 6:59 AM
Good morning.
Check the hoses that go to the intake for any damage or loose clamps. if you can, pressure test the cooling system to find the leak. you can rent a tester at a parts store if you do not have a tester.
As far as the oil leak, it could be valve cover gaskets seeping onto the manifold. if all these checks are good, it is a very good chance the intake manifold itself is leaking.
Mar 19, 2018 at 10:02 PM
