Leaking washer fluid
44,000 MILES • V6 • 4WD
PATHFINDER 2008
I have a leaking washer fluid.everytime i refill the washer fluid it goes out really fast.
Jan 29, 2019 at 5:34 AM
  • 110,248 POSTS
Chances are the reservoir is cracked or the pump is leaking. What I suggest is removing the tank for inspections. Here are the directions for removal. The attached pictures correlate with these directions.
_________________________
FRONT AND REAR WASHER FLUID RESERVOIR
Removal
1. Remove passenger front fender protector.
Picture 1
2. Remove clip, then remove washer fluid reservoir filler neck from washer fluid reservoir.
Picture 2
3. Disconnect front and rear washer hoses.
4. Disconnect front and rear washer motor connector.
5. Disconnect washer fluid level sensor connector.
Picture 3
6. Remove washer fluid reservoir screws and remove washer fluid reservoir.
Installation
Installation is in the reverse order of removal.
CAUTION: After installation, add water up to the upper level of the washer fluid reservoir inlet and check for water leaks.
_________________________________________
Once you remove it, let me know what you find. If you need help or have other questions, let me know.
Jan 29, 2019 at 10:49 AM
