Leaking valve cover gasket
237,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
TMCINTOSH11
  • 176 POSTS
I just noticed my valve cover gasket was leaking, and before I get into replacing it, is there a effective stop leak I could try? Or a sealant I can put around the leaking side? It is on the driver's side and I would have to take the intake off too just to get to it and I am really really dreading it. It is not losing a lot of oil and it seeps just enough to smoke on the side of the engine, it has not made it way to the manifold yet thank god, I am planning on replacing it this weekend but I did not know if there could be an easier way out of this mess. Thanks guys!
Oct 5, 2017 at 10:29 AM
STEVE W.
  • 15,411 POSTS
Clean off all the oil you can and see if you can tighten any of the bolts. They are stopped by the shoulder inserts in the cover so do not go gorilla on them if they do not want to move or you can break off the bolt.
Other than that there is no anything that would really help without possibly making things worse.
Oct 5, 2017 at 2:05 PM
TMCINTOSH11
  • 176 POSTS
Thanks for letting me know, before I get into it can you tell me what I am in for as far as getting the old gasket off and how I should put the new one on? Like maybe if there is a kind of sealant I should use with the new one? Thanks!
Oct 6, 2017 at 10:00 PM
STEVE W.
  • 15,411 POSTS
It should peel off pretty easy. Lay the cover on a flat surface to be sure it is not warped along the edges. Generally I install VC gaskets dry, especially the newer rubber/silicone type like your engine uses. I will say that while you have things apart it is a good time to check over all the stuff hidden under the intake.
Oct 7, 2017 at 12:08 PM
TMCINTOSH11
  • 176 POSTS
Cool, thanks for your help!
Oct 8, 2017 at 5:09 AM
