leaking transmission line
195,000 MILES
GDFARRELL
I noticed a drip at the connection of my transmission line to my radiator. I notice there are three fitings associated with this. Can i replace these one at a time to determine which needs to be fixed. I am not a mechanic but can do a little. Or is this a common thing.
May 10, 2013 at 12:44 AM
HMAC300
  • 48,601 POSTS
check to see if it's a cracked line first or a bad O-ring. then look to see if its' cracked around the radiator. if it's a line you can put apiece of hose over it with a couple of clamps. the truck is almost 20 yrs old so something will leak in that time span it can be common with age
Mar 24, 2021 at 6:19 AM
