leaking trannsmission fluid and hits when put in reverse
150,000 MILES
FRANKARCHULETA1
  • 8 POSTS
I noticed my trannsmission was leaking, I let it run and watched it it looks like its coming from the end part of the trannsmission on the drivers side only does it when its hot, would could it be? As well when I put my car in reverse it kind of hits mainly in reverse not so bad when changing gears? Could I need a whole new transmission?
Oct 23, 2013 at 12:55 PM
SATURNTECH9
  • 30,868 POSTS
So the transmission side cover is leaking? As far as the delay bang into reverse? It could be a low pressure issue inside the transmission or a loose input shaft nut.Pressure test on the transmission will tell you which is the problem.
Oct 23, 2013 at 4:06 PM
FRANKARCHULETA1
  • 8 POSTS
Its a automatic, and that's what it looks like its like the cap looking side on the drivers side behind the wheel
Oct 23, 2013 at 8:31 PM
SATURNTECH9
  • 30,868 POSTS
So is it leaking from the gasket area or the cover itself?
Oct 24, 2013 at 2:44 AM
