Leaking rear air bags
125,000 MILES
FERNANDO BOU
My rear electronic suspension is leaking. Can this be repaired or does it need to be replaced?
May 18, 2019 at 4:07 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Before I can help diagnose is your truck a 2wd or 4wd? Also it would help to know if your engine displacement is 4.6L or 5.7L. Look forward to hearing back from you and thanks for using 2CarPros.
Danny-
May 19, 2019 at 5:35 AM
FERNANDO BOU
5.7, Two wheel drive.
May 19, 2019 at 12:58 PM
  • 55,688 POSTS
Yes, the air bags go out all the time on these. you can do it yourself, just get the new airbags and disconnect the battery or turn the suspension switch off. here are the instructions and diagrams below to help you get the job done. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
May 23, 2019 at 5:01 AM
