Leaking radiator coolant out of rear freeze plug. I think losing radiator coolant back there some where.
Aug 21, 2018 at 7:48 AM
DANNY L
✓Experienced Mechanic
Hello, I am Danny.
The best thing to do is use a coolant system pressure tester to find the leak. Most local auto parts stores have a tool loaner program that allows you to rent one.It then pressurizes the cooling system with the car not running a will pinpoint where the leak is coming from. I am attaching a tutorial showing you how to do it. Hope this helps and feel free to ask any questions if needed. Thanks for using 2CarPros.
Danny-
