Leaking Power steering fluid and still Steering
324,000 MILES • 3.6L • 6 CYL • 4WD • AUTOMATIC
SETTLEMENTZ
I have replaced the the Rack and Pinion also Tie Rod...then .Beerings and Ball Joints but yet I am still having to fight to turn and constant sqeeking sound.
Dec 19, 2014 at 6:38 AM
JOHNNYT73
  • 924 POSTS
Its may be the strut mounts/bearings (disregard if that is what you meant by bearings). Have you tried spraying the u-joint in the intermediate shaft with some lubricate or replacing it to see if that is the issue?
Dec 19, 2014 at 7:10 AM
JOHNNYT73
  • 924 POSTS
If your leaking fluid then you need to check your steering lines for leaks. Also you may need a new pump. You need to bleed all the air out of the system. Leave the cap off and steer the wheels from stop to stop a bunch and let it run about 2 minutes between steering.
Dec 19, 2014 at 7:12 AM
