leaking oil ? but bolts where missing from left drivers side interior of engine 4
97,000 MILES • 4 CYL • MANUAL
GMAZDA
hello my mazda miata has an oil leak, put 1 quart of oil in and it came out in my driveway. Checked and 4 bolts from drivers side engine were missing. I replaced them then cleaned engine with fluid and hose. Oil still speeping from drivers side engine seal and round cap at rear of drivers side engine. can i replace the gasket seal myself? how much should it cost? what do I call the part engine gasket?
Jun 19, 2014 at 4:00 AM
RACEFAN966
  • 5,029 POSTS
Can you include a pic of what you are referring to? I can then tell you what it called and give you answers and probably walk you though the fix too. Thanks
Jun 20, 2014 at 12:42 AM
