leaking coolant out back of thermerstat housing
2005 BUICK RENDEZVOUS
6.3L • 6 CYL • 2WD
F0X1311
I see where it is leaking from the back of housing at the house I don't know how to go about removing it
Feb 14, 2015 at 6:02 AM
JDL
  • 16,098 POSTS
Did you try to tighten the hose clamp? The thermostat housing bolts have proper torque?This info is for 3.4L cx engine.
Remove the air cleaner and duct assembly.
Drain coolant until coolant is below the thermostat.
Remove the crossover exhaust pipe.
Remove radiator hose from thermostat housing.
Remove the thermostat housing bolts and so on.
Feb 14, 2015 at 7:14 AM
