leaking coolant and car not accelerating
155 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
NIKKIR
I just replace my radiator and my vehicle is still leaking and ever time I drive it it goes slow and it seems like it wants to stop.
Jun 2, 2016 at 10:31 PM
HMAC300
  • 48,601 POSTS
have the coolant system pressure checked for an internal leak like a head gasket.
Jun 2, 2016 at 10:34 PM
NIKKIR
Would my vehicle leak coolant if the radiator fan is not spinning?
Jun 2, 2016 at 10:49 PM
HMAC300
  • 48,601 POSTS
only if the fan does not work at idle and when the air conditioner is on while driving, it does not matter to much. It would not leak coolant anyhow it would blow it out the reservoir and your engine gauge would say hot or towards that, but have it pressure checked anyhow.
Jun 3, 2016 at 12:11 AM
NIKKIR
If my water pump or my thermostat need to be change would it leak coolant?
Jun 3, 2016 at 12:33 AM
HMAC300
  • 48,601 POSTS
pressure check this as I think you have a head gasket going out or have a professional look at it. if it was the thermostat it would over heat almost immediately, but there would be no power loss.
Jun 3, 2016 at 1:08 AM
