leaking coolant
2005 MERCEDES BENZ ML350
145,000 MILES • 6 CYL • 4WD • AUTOMATIC
E NASCIMENTO
fluid light comes on I put in coolant light goes off within a short time it is empty again. reservor is empty light is on
Dec 16, 2018 at 6:05 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny,
Do you happen to see any type of leak? Is it dripping anywhere on the ground or just disappearing? Hope this helps and thanks for using 2CarPros. A cooling system pressure test can show the location of a leak.If you don't have access to one your local auto parts have a tool loaner program and will rent you one. I have attached a tutorial showing what is involved.
https://www.2carpros.com/articles/radiator-pressure-test
Hope this helps and feel free to ask any questions if needed.Thanks for using 2CarPros.
Danny-
Dec 16, 2018 at 6:45 AM
