Leaking coolant
96,000 MILES • AUTOMATIC
TRAVIS BUTLER2
  • 83 POSTS
Leaking coolant from heater blower housing lines and heater core are fine.
Oct 19, 2020 at 9:18 AM
Just to confirm what you are dealing with. You are leaking coolant inside the vehicle from the heater box and the lines and heater core are not the issue?
If this is the case, we need to pressurize the coolant system and access the box under the dash by removing the blower motor and try ti find the source of the leak. You can also use a borescope if needed. However, the most common failure is a line or heater core for a leak inside the vehicle but if they are not the cause, we need to find the access point to the inside so that we can see what other possible causes are.
https://www.2carpros.com/articles/radiator-pressure-test
Oct 19, 2020 at 9:33 AM
TRAVIS BUTLER2
  • 83 POSTS
It's not coming from inside truck it's coming from under hood, but it takes 45 minutes or so to start leaking.
Oct 19, 2020 at 9:45 AM
TRAVIS BUTLER2
  • 83 POSTS
We did a pressure test like I said it looks like it is coming from the heater fan housing from under the hood at the seam.
Oct 20, 2020 at 3:46 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
In situations like this what we ask you to do is use your cell phone to take a picture of where the leak is and upload here so we can both be on the same page. Hope this helps and thanks again for using 2CarPros.
Oct 20, 2020 at 3:51 PM
TRAVIS BUTLER2
  • 83 POSTS
No thanks we found the problem.
Oct 20, 2020 at 4:10 PM
DANNY L
  • 5,648 POSTS
Hello again.
Glad to hear you found the problem and were able to fix. Hope you will use our site again in the future . Thanks again for using 2CarPros.
Danny-
Oct 20, 2020 at 4:27 PM
  • 55,746 POSTS
Can we ask what the problem was?
Oct 22, 2020 at 5:24 AM
