coolant leak coming from the thermostat gasket
500,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
AMANDA WEYMAN
We have a coolant leak coming from the thermostat gasket near the bypass pipe, but only leaks when cold.
Sep 16, 2016 at 6:46 PM
HMAC300
  • 48,601 POSTS
we have no pictures of this, but if gasket is leaking replace the thermostat and gasket . also, look for etching on thermostat housing. it may be bad as well.
Sep 17, 2016 at 3:11 AM
AMANDA WEYMAN
We have replaced the thermostat and gasket when we changed the water pump and that was on the 6 June this year.
Sep 17, 2016 at 12:11 PM
CJ MEDEVAC
  • 11,000 POSTS
