Leaking coolant
179,000 MILES • 1.9L • 4 CYL • 2WD • MANUAL
MR. TEE
My car coolant dries up and the temperature rises when i drive for 25 miles and when the car is stable, it begins to shake/vibrate vigorously while producing a thick white smoke from the exhaust.
May 12, 2022 at 9:03 AM
SQM
  • 6,383 POSTS
White smoke out of the exhaust happens when coolant enters mixes with oil due to a leak in the head gasket.
The first step would be to determine if indeed you have a blown head gasket.
Usually, coolant will change the color of the oil to a milky white color.
Take a look at this guide, it shows what to look for and test to determine a blown head gasket:
You have listed the engine as a 1.9L, can you confirm that it is a 1.9L and not the 1.8L.
Let me know what you find or if you have any questions.
May 12, 2022 at 10:33 AM
