Leaking around the thermostat housing
100,000 MILES • 2.7L • V6 • 2WD • AUTOMATIC
PAPAJOHN84
I changed the thermostat and the thermostat housing both brand new, but it is still leaking around the bottom bolt. what could be the problem?
Mar 28, 2019 at 7:28 AM
SCGRANTURISMO
  • 4,897 POSTS
Are you sure that you got the correct neck for your make and model of vehicle? Also make sure that the gasket isn't pinched or binding in any way. The intake manifold or head, whatever the neck is bolted to might have a hairline crack where the bolt bolts into. Try this trick, smear some RTV, preferably the red high temperature, on the threads of the leaking bolt and then re-tighten. Wait for a couple of hours to make sure it's good and cured and then test to see if it sealed. Get back to us with what you find out.
Thanks,
Alex
2CarPros
Sep 24, 2020 at 3:07 AM
