Leaking antifreeze
154,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
DAVE$
With the engine running antifreeze is pouring out where the transmission bolts on to the engine. this is no small leak it’s like it’s being pumped out.
Aug 11, 2019 at 12:35 AM
Hi Dave,
Can you get a picture or video of this leak? Just fill it with water and then start the engine. No sense in wasting coolant or letting it possibly run dry.
This could be a cooling line, passage, or the head gasket itself. However, seeing it may help identify what is causing it. Thanks
Oct 3, 2020 at 4:16 AM
