Leaking under middle of the engine I don't know if it's leaks while driving but when I turn engine off drips very fast
Sunday, July 12th, 2015 AT 4:38 AM
MECHANIC
Check for loose drain plug leaking drain plug seal, damaged sump, leaking front or rear main oil seal, loose oil filter, all common causes for engine oil leaks.
SPONSORED LINKS
Sunday, July 12th, 2015 AT 5:45 AM
MECHANIC
Sorry, not a oil leak. Start with a cooling system pressure test, this will help locate any external coolant leak, this will probably be a leaking hose.
