leak of antifreeze
150,000 MILES
SHAYLUV1989
about a month a go i fixed my water pump and timing belt because they went out i havn't had a problem until today that i know of antifreeze is coming from the same place.???? i don't know why or why it would take this long for it to leak again if i didn't put it in right which im sure i did.. also it seems like my engine sound like it will die sometimes after 5 hours of sitting and i turn it on... i tap the gas a little so the idle is high when i turn it off and it seems to help but i really don't want to flood the engine either ???? and my lights flicker on my car dash and head lights i cant use my raido because im afraid it will go out for good but iv had an electric problem since i got it the engine is a 3.2
May 4, 2013 at 4:28 AM
since we have no engine size we will generalize.
have the system pressure tested to confirm where the leak is located. then you can proceed with the repair
Oct 19, 2018 at 4:17 AM
SHAYLUV1989
its a 3.2 engine
