leak in power steering mechanism
1991 CHEVROLET LUMINA
178,000 MILES
LAYNETD2013
A few years ago I had the power steering pump and both the high/low pressure lines on my 91 Lumina Eurosport replaced. Some time after that I started losing power steering fluid and had a mechanic check the problem out and he suggested replacing the fluid lines again so that's what I had him do. However, this did not fix my problem and I continue to lose fluid. I have checked the pump on the engine and it doesn't appear to be leaking. The unit works fine as long as I keep it full of fluid but it leaks out slowly somewhere and I have not been able to determine where the leak is. The steering works fine otherwise. Can you possibly give me any idea what to do now or are there any trouble spots associated with this cars steering mechanism I need to know about. Any information would be most useful. Thank you!
May 24, 2013 at 10:15 AM
CARADIODOC
  • 34,381 POSTS
If you are not seeing a puddle or spots anywhere, the most likely cause is a leaking seal in the rack and pinion steering gear. There's an accordion boot on each side. Slide the small clamp off one of them, then use a screwdriver or hooked tool to pull it open and see if any fluid runs out.
May 24, 2013 at 12:25 PM
LAYNETD2013
thank you so much, I have not really noticed any puddles under the car but it leaks out very slowly over time. I will check those seals and see if that could be my problem. Thanks again and have a wonderful evening.
May 24, 2013 at 12:29 PM
